Ich kann den Fehler nicht reproduzieren. Bei mir kommen alle Felder:
"data": {
"id": "230",
"name": "Matrix Product API-Test",
"description": null,
"shortDescription": "",
"number": "1000070",
"project": {
"id": "1",
"name": "Standard Projekt"
"category": {
"id": "5",
"name": "Fremdleistung"
"standardSupplier": null,
"stockCount": 0,
"shopPriceDisplay": "0.00",
"ean": null,
"manufacturer": {
"name": null,
"number": null,
"url": null
"customsTariffNumber": null,
"options": [
"id": "36",
"name": "Size",
"values": [
"id": "56",
"name": "L",
"sort": 1
"id": "57",
"name": "M",
"sort": 2
"id": "37",
"name": "Color",
"values": [
"id": "58",
"name": "Red",
"sort": 1
"id": "59",
"name": "Blue",
"sort": 2
"variants": [],
"thumbnailUrl": null,
"tags": [],
"freeFields": [],
"countryOfOrigin": null,
"internalComment": "",
"isDeleted": false,
"measurements": {
"weight": {
"value": 0,
"unit": "kg"
"netWeight": {
"value": 0,
"unit": "kg"
"length": {
"value": 0,
"unit": "cm"
"width": {
"value": 0,
"unit": "cm"
"height": {
"value": 0,
"unit": "cm"
"minimumOrderQuantity": 0,
"minimumStorageQuantity": 0,
"salesTax": "standard",
"hasBatches": false,
"serialNumbersMode": "disabled",
"hasBestBeforeDate": false,
"hasBillOfMaterials": false,
"isAssembledJustInTime": false,
"isProductionProduct": false,
"isExternallyProduced": false,
"allowPurchaseFromAllSuppliers": false,
"isDisabled": false,
"disabledReason": "",
"hidePriceOnDocuments": false,
"ageRating": null,
"isStockItem": false,
"isStockTakingDisabled": false,
"isCustomProduct": false,
"hideJustInTimeItemsOnDocuments": false,
"markAsSoldOut": false,
"markAsInactive": false,
"isRemainingQuantity": false,
"updatedAt": "2023-03-10T09:26:03+01:00"
Kannst du mir hier den Call schreiben, der du aufrufst?
Danke!
Chuck.
