Transfer correct discounts per product does not work..
We sell b2b with WholesaleGorilla and that means all products gets discount. This is shown clearly in Shopify of course, but when imported into Xentral then it leaves the products original price and inserts a new product at the bottom with the combined sum of the discount. How can we get the discount per product shown in bills and invoices?
Thanks for the help!
Hi @marcustonndorf ,
this describes the general logic of how Xentral takes over discounts from the shop - not for each item, but as a separate discount item for the entire order. Ideally, this can be adjusted using Smarty Custom Code, otherwise only with a direct marketplace connection, instead of going through Shopify.
best, daniel
This logic would however not fit any use case that I can think of where individual products are discounted and a system summarise it to one. What is a direct marketplace connection, is that not what you offer with to Shopify? Can you please show us a code which would work with this “smarty thing” so we can get this up an running asap. Thanks Daniel
