BerichteGet from api
  • February 20, 2021
  • 189 Ansichten
Ali Bagherzadeh
Hi everyoneI am trying to fetch report data via the below link
 'https://{account}.xentral.biz/index.php?module=api&action='.$methodname.'&hash='.$hash.'&id='.$id.'&api_id=4';method name as i found from documentation should be BerichteGet also I set the rport id but it return below error [status] => SimpleXMLElement Object([action] => BerichteGet[message] => Invalid key (id)[messageCode] => 5)how can I recheck the report id is set correctlyI take report id and ap_id from thess places
Beste Antwort von Got Bag GmbH
I found a solution for the problem "BerichteGet". This API Call "BerichteGet" from the Xentral-API only get results from the module "Berichte (Legacy)". The screenshot shows a report from the module "report" which is only available via REST-API (as mentoined above). Hope this helps everyone who has the same question and comes to this topic.
Maybe you're using the wrong URL to fetch the report.
Manual says "Wie der Bericht per REST-API aufgerufen wird, kann der REST-API Dokumentation entnommen werden. Endpunkt: /v1/reports"
API documentation:
https://update.xentral.biz/apidoc/docs203.html#v1_reports__id__download_get
  • July 16, 2021
