Hi everyoneI am trying to fetch report data via the below link
Maybe you're using the wrong URL to fetch the report.
Manual says "Wie der Bericht per REST-API aufgerufen wird, kann der REST-API Dokumentation entnommen werden. Endpunkt: /v1/reports"
API documentation:
https://update.xentral.biz/apidoc/docs203.html#v1_reports__id__download_get
I found a solution for the problem "BerichteGet". This API Call "BerichteGet" from the Xentral-API only get results from the module "Berichte (Legacy)". The screenshot shows a report from the module "report" which is only available via REST-API (as mentoined above). Hope this helps everyone who has the same question and comes to this topic.
