HiI want to fetch order shipment information ( such as provider name, tracking code,...)would you let me know should I search for this information inside order information or should fetch this data from another endpoint? regards
Buchseite 1 / 1
Isn't –at least the tracking code– related to the delivery note (Lieferschein), not "order information"?
Here is an API documentation if it helps... https://update.xentral.biz/apidoc/docs203.html
Thanks for replyas I found there is no direct API access for such information need to use report feature for it
Anmelden
Willkommen
Login über soziales Netzwerk
Anmelden mit Facebook Anmelden mit LinkedInoder
