Smarty Shopimporer - Freifelder korrekt mappen
  • February 16, 2024
  • 0 Antworten
  • 73 Ansichten
benLK
Hallo Community,
wir arbeiten mit dem Magento 2 Shopimporter. Via Smarty im Shopimporter möchte ich gern spezifische Werte aus Custom Options Fehldern in zwei Freifelder “printen”.
Die Werte kommen als Array an:
Das Datum     [3] => 2024-10-04  aus der [option_id] => 2011 möchte ich in mein freifeld_9 in Xentral schreiben.
Die Werte aus  [option_value] => Igel.tif, Schwan.tif, Taube.tif und   [option_id] => 2012 möchte ich in freifeld_13 in Xentral schreiben
Die Werte kommen so an:
[product_option] => Array
[extension_attributes] => Array
[custom_options] => Array
[0] => Array
[option_id] => 2011
[option_value] => Array
[0] => 4
[1] => 10
[2] => 2024
[3] => 2024-10-04 00:00:00
[1] => Array
[option_id] => 2012
In der Xentral Hilfe finde ich die Info:
Loops
Loops allow the processing of value lists (arrays), e.g. order items, tax rates, or similar. The results are usually key-value pairs, which can then be evaluated in a second step. For this purpose, these lists are run through and processed in a loop.
In the following example, for a given structure of the billing address, an arbitrary element is picked out, e.g. to set a separate setting for the country.
Example: Shopimporter
Shopping cart:
billing => [
 0 => [name => country, value => DE],
 1 => [name => street, value => Musterweg],
 2 => [name => house_no, value => 2],
 3 => [name => phone, value => 123456789],
 4 => [name => first_name, value => Max],
Template:
<xml>
 {foreach key=billingKey item=billingData from=$cart->billing}
   {if $billingData->name == ”country”}
     <land>{$billingData->value}</land>
   {/if}
 {/foreach}
</xml>
Nun versuche ich mich im Smarty Template mit der Einstellung “Warenkorb transformieren aktiv” = YES mit dem folgenden:
<xml>
{foreach from=$cart.item.product_option.extension_attributes.custom_options item=option}
{if $option.option_id == 2011}
<freifeld_9><![CDATA[{$option.option_value[3]}]]></freifeld_9>
{/if}
{if $option.option_id == 2012}
<freifeld_13><![CDATA[{$option.option_value}]]></freifeld_13>
{/if}
{/foreach}
</xml>
Leider ohne Erfolg,
Sieht jemand vielleicht auf Anhieb, was genau das Problem ist?
Ben
