Xentral EC2 Installation. Port 80 issue
  • May 5, 2022
  • 70 Ansichten
Ronny
Hi together,
we are using the self hosted version of xentral.
We use purely https. But sometimes we have actually the issue that it redirects to port:80
  1. Is there somewhere a setting to set to https only?
  2. any other solution
Sample after scan:
Is: :80/www/index.php?module=lagermobil
Should be: /www/index.php?module=lagermobil
Thanks
Ronny
Beste Antwort von Anonymous
Hey @Ronny !
Thank you for posting in our community! I want to welcome you to this super cool space! :)
For this issue I can just make some suggestions:
This is probably a problem with the web server configuration. For example, https is always forced on our instances.
However, the behaviour can also be enforced by browser add-ons such as https everywhere.
Let me know if you have any more questions about this. :)
Cheers,
  • May 12, 2022
Hey @Ronny !
Cheers,
