Business letter template
  • May 6, 2022
  • 46 Ansichten
Vitaliy
I want to create business letter template with some kind of products table, which will display sales order products with their price, quantities, total amounts is it possible to do on Xentral, because I can't found any variables for this?
Hey Vitaliy,
you may find a solution with template scripts. If you are on the cloud we can upload them for you. You can find detailed instructions for template scripts in this manual entry. I would love to support you deeper, however this goes far beyond what we can do.
If you need support beyond that, it's best to contact our partner, e.g.:
BuI Hinsche GmbH
Matthias Hinsche
03441 9799060
info@bui-hinsche.com
Neumarkt 7
DE-06712 Zeitz
You can also book a free initial consultation at https://calendly.com/bui-hinsche/kostenfreie-video-erstberatung
Note: Please note that there may be additional costs for partner services, about which we can not give exact information.
Best regards,
Dennis Frick
  • May 25, 2022
Hey Vitaliy,
BuI Hinsche GmbH
Matthias Hinsche
03441 9799060
Neumarkt 7
DE-06712 Zeitz
Best regards,
