order shipment information
  • January 14, 2021
  • 44 Ansichten
Ali Bagherzadeh
HiI want to fetch order shipment information ( such as provider name, tracking code,...)would you let me know should I search for this information inside order information or should fetch this data from another endpoint? regards
Beste Antwort von Ali Bagherzadeh
Thanks for replyas I found there is no direct API access for such information need to use report feature for it
Isn't –at least the tracking code– related to the delivery note (Lieferschein), not "order information"?
Here is an API documentation if it helps... https://update.xentral.biz/apidoc/docs203.html
Ali Bagherzadeh
  • February 19, 2021
